- Thu Jan 25, 2018 9:03 am
#73480
I have purchased a wifi touch light switch and it has a esp8266mod chip on it. I want to reprogram this with new firmware. .. I have connected as per the many instructions with its own power supply and can put it in normal or boot mode etc. It works at 74880 baud and i can see either a boot message or normal startup sequence with i reset the chip. I cant get the chip to accept any AT commands or any connection with esptool or the nodemcu flasher tool. I can see the transmit light sending the commands but no response. Can the manufacturers lock these down and if so how.. I guess as a minimum they could remove the AT functions, but what about stopping the esptool, nodemcu flasher etc. Is this likely to be my inexperience trying to do this or how do i circumvent
Are there any other tools I could try to erase the existing firmware. thanks ste (not after boot i have tried changing to 115200 with no luck) and i have left the pins in the same state as at startup.. eg gpi02 is still low etc
