https://github.com/JhonControl/Arduino_ ... aveTCP-RTU
http://pdacontrolen.com/tutorial-esp826 ... tu-master/
viewtopic.php?f=11&t=2442
I don't know much about modbus, and don't have any modbus devices, so I doubt I would be much help as far as your problem. But it sounds like it might not be too hard a problem. If you post your code maybe someone can see what the problem is.
I had a look at the links , it seems to be different . My aim is to have a esp8266 device act as a modbus tcp server (slave) , it acts as a rtu master . It should work as a transparent modbus gateway .
#include <SoftwareSerial.h>
#include <WiFiClient.h>
const char* ssid = "..........";
const char* password = "..............";
// Start a TCP Server on port 502
WiFiServer server(502);
WiFiClient client ;
const long interval = 50 ; // interval (milliseconds)
size_t len = 255;
uint8_t sbuf[255];
uint8_t rtu_buf[255];
uint8_t rtu_len;
uint16_t calcCRC(uint8_t u8_buff_size)
uint32_t tmp, tmp2, flag;
tmp = 0xFFFF;
for (uint8_t i = 0; i < u8_buff_size; i++)
tmp = tmp ^ rtu_buf[i];
for (uint8_t j = 1; j <= 8; j++)
flag = tmp & 0x0001;
tmp >>= 1;
if (flag)
tmp ^= 0xA001;
tmp2 = tmp >> 8;
tmp = (tmp << 8) | tmp2;
tmp &= 0xFFFF;
return tmp;
pinMode(D0,OUTPUT); //re rs485
WiFi.begin(ssid,password);
//Wait for connection
while(WiFi.status() != WL_CONNECTED) {
delay(100);
//swSer.print(".");
server.begin();
bailout:
Serial.flush();
yield();
if (!client.connected()) {
client = server.available();
else{
if (client.available() > 0) {
int readnum = client.read(sbuf,client.available());
rtu_len = sbuf[5];
for (int i=0 ;i<readnum-6;i++){
rtu_buf[i] = sbuf[i+6];
int value = calcCRC(rtu_len);
rtu_buf[rtu_len] = (value & 0xFF00) >> 8;
rtu_buf[rtu_len+1] = value & 0x00FF;
Serial.flush();
digitalWrite(D0,HIGH);
delay(1);
Serial.write(rtu_buf,rtu_len + 2);
Serial.flush();
digitalWrite(D0,LOW);
memset(rtu_buf, 0, 50);
while(!Serial.available()){
yield();
if( millis() - currentMillis > interval){
goto bailout;
int i = 6;
while (Serial.available() > 0) {
rtu_buf[i] = Serial.read();
i ++;
yield();
goto bailout;
if ( i > 10){
rtu_len = i- 2;
rtu_buf[5] = rtu_len -6 ;
rtu_buf[0] = sbuf[0];
rtu_buf[1] = sbuf[1];
client.write((const uint8_t*)rtu_buf,rtu_len);
Serial.flush();
//Unfortunately there is a bad function overload in the library,
//but you can just typecast the clientbuf to overcome this problem.....
// eg ... client.write((const uint8_t*)clientBuf, sizeof(clientBuf));
