By moose4621
#74104 I think have bitten off more than I can chew, again. :oops:
I have adapted and merged several arduino sketches to ultimately control a stepper motor at a set speed via websocket. I based most of the sketch on this great example which worked well before I modified the hell out of it.
The result now is the index.html displays pretty close to what I want but the checkbox's and number box do not return data and the start and stop buttons work once only. ie after a reset, I can start and then stop the motor but then it will not start again.
I must admit that even though I have used such a great websocket example and used this great reference also, I still have trouble understanding exactly what is going on in the sketch. :?
I am quite excited about the potential of this sketch because for many months I was unable to run a stepper motor while the wifi was active because of interference of the stepper pulses but I recently tried the AccelStepper library and all the interference problems went away.
The hardware is a Wemos D1mini running a stepper driver such as a TB6600, I will eventually also have a gps receiver and a proximity sensor attached but they will come later.
I would appreciate any assistance given. Thanks in advance, Chris.
#include <ESP8266WiFiMulti.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <FS.h>
#include <WebSocketsServer.h>
ESP8266WiFiMulti wifiMulti;       // Create an instance of the ESP8266WiFiMulti class, called 'wifiMulti'
ESP8266WebServer server = ESP8266WebServer(80);       // create a web server on port 80
WebSocketsServer webSocket = WebSocketsServer(81);    // create a websocket server on port 81
File fsUploadFile;                                    // a File variable to temporarily store the received file
const char *ssid = "ESP8266 Access Point"; // The name of the Wi-Fi network that will be created
const char *password = "";   // The password required to connect to it, leave blank for an open network
const char *OTAName = "ESP8266";           // A name and a password for the OTA service
const char *OTAPassword = "esp8266";
const char* mdnsName = "esp8266"; // Domain name for the mDNS responder
//for motor control*************
#include <AccelStepper.h>
AccelStepper stepper(1, 4, 5);
float setpointVariable;//Fixed at 20rpm for now.
long steps = 200;//steps per revolution
long microStep = 16;//microstepping
bool motorStatus;// Current motor status
/*__________________________________________________________SETUP__________________________________________________________*/
  pinMode(4, OUTPUT);    // step
  pinMode(5, OUTPUT);    // dir
  Serial.begin(115200);        // Start the Serial communication to send messages to the computer
  delay(10);
  Serial.println("\r\n");
  startWiFi();                 // Start a Wi-Fi access point, and try to connect to some given access points. Then wait for either an AP or STA connection
  startOTA();                  // Start the OTA service
  startSPIFFS();               // Start the SPIFFS and list all contents
  startWebSocket();            // Start a WebSocket server
  startMDNS();                 // Start the mDNS responder
  startServer();               // Start a HTTP server with a file read handler and an upload handler
  stepper.setMaxSpeed(3200);
  stepper.setSpeed(0);//pulses per second
  stepper.setAcceleration(1);
/*__________________________________________________________LOOP__________________________________________________________*/
bool sendstart = false;             // The rainbow effect is turned off on startup
bool sendstop = true;
bool sendRPM = false;
bool sendlinkage;
bool sendvrate;
unsigned long prevMillis = millis();
int hue = 0;
  webSocket.loop();                           // constantly check for websocket events
  server.handleClient();                      // run the server
  ArduinoOTA.handle();                        // listen for OTA events
  stepper.runSpeed();
  if(sendstart) {
    stepper.setSpeed(setpointVariable/60*steps*microStep);
    Serial.println(stepper.speed());
  else {
/*__________________________________________________________SETUP_FUNCTIONS__________________________________________________________*/
void startWiFi() { // Start a Wi-Fi access point, and try to connect to some given access points. Then wait for either an AP or STA connection
  WiFi.softAP(ssid, password);             // Start the access point
  Serial.print("Access Point \"");
  Serial.print(ssid);
  Serial.println("\" started\r\n");
  wifiMulti.addAP("ssid_from_AP_1", "your_password_for_AP_1");   // add Wi-Fi networks you want to connect to
  wifiMulti.addAP("ssid_from_AP_2", "your_password_for_AP_2");
  wifiMulti.addAP("ssid_from_AP_3", "your_password_for_AP_3");
  Serial.println("Connecting");
  while (wifiMulti.run() != WL_CONNECTED && WiFi.softAPgetStationNum() < 1) {  // Wait for the Wi-Fi to connect
    delay(250);
    Serial.print('.');
  if(WiFi.softAPgetStationNum() == 0) {      // If the ESP is connected to an AP
    Serial.println(WiFi.SSID());             // Tell us what network we're connected to
    Serial.print("IP address:\t");
    Serial.print(WiFi.localIP());            // Send the IP address of the ESP8266 to the computer
  } else {                                   // If a station is connected to the ESP SoftAP
    Serial.print("Station connected to ESP8266 AP");
void startOTA() { // Start the OTA service
  ArduinoOTA.setHostname(OTAName);
  ArduinoOTA.setPassword(OTAPassword);
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
    Serial.println("\r\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("OTA ready\r\n");
void startSPIFFS() { // Start the SPIFFS and list all contents
  SPIFFS.begin();                             // Start the SPI Flash File System (SPIFFS)
  Serial.println("SPIFFS started. Contents:");
    Dir dir = SPIFFS.openDir("/");
    while (dir.next()) {                      // List the file system contents
      String fileName = dir.fileName();
      size_t fileSize = dir.fileSize();
      Serial.printf("\tFS File: %s, size: %s\r\n", fileName.c_str(), formatBytes(fileSize).c_str());
    Serial.printf("\n");
void startWebSocket() { // Start a WebSocket server
  webSocket.begin();                          // start the websocket server
  webSocket.onEvent(webSocketEvent);          // if there's an incomming websocket message, go to function 'webSocketEvent'
  Serial.println("WebSocket server started.");
void startMDNS() { // Start the mDNS responder
  MDNS.begin(mdnsName);                        // start the multicast domain name server
  Serial.print("mDNS responder started: http://");
  Serial.print(mdnsName);
  Serial.println(".local");
void startServer() { // Start a HTTP server with a file read handler and an upload handler
  server.on("/edit.html",  HTTP_POST, []() {  // If a POST request is sent to the /edit.html address,
    server.send(200, "text/plain", "");
  }, handleFileUpload);                       // go to 'handleFileUpload'
  server.onNotFound(handleNotFound);          // if someone requests any other file or page, go to function 'handleNotFound'
                                              // and check if the file exists
  server.begin();                             // start the HTTP server
  Serial.println("HTTP server started.");
/*__________________________________________________________SERVER_HANDLERS__________________________________________________________*/
void handleNotFound(){ // if the requested file or page doesn't exist, return a 404 not found error
  if(!handleFileRead(server.uri())){          // check if the file exists in the flash memory (SPIFFS), if so, send it
    server.send(404, "text/plain", "404: File Not Found");
bool handleFileRead(String path) { // send the right file to the client (if it exists)
  Serial.println("handleFileRead: " + path);
  if (path.endsWith("/")) path += "index.html";          // If a folder is requested, send the index file
  String contentType = getContentType(path);             // Get the MIME type
  String pathWithGz = path + ".gz";
  if (SPIFFS.exists(pathWithGz) || SPIFFS.exists(path)) { // If the file exists, either as a compressed archive, or normal
    if (SPIFFS.exists(pathWithGz))                         // If there's a compressed version available
      path += ".gz";                                         // Use the compressed verion
    File file = SPIFFS.open(path, "r");                    // Open the file
    size_t sent = server.streamFile(file, contentType);    // Send it to the client
    file.close();                                          // Close the file again
    Serial.println(String("\tSent file: ") + path);
    return true;
  Serial.println(String("\tFile Not Found: ") + path);   // If the file doesn't exist, return false
  return false;
void handleFileUpload(){ // upload a new file to the SPIFFS
  HTTPUpload& upload = server.upload();
  String path;
  if(upload.status == UPLOAD_FILE_START){
    path = upload.filename;
    if(!path.startsWith("/")) path = "/"+path;
    if(!path.endsWith(".gz")) {                          // The file server always prefers a compressed version of a file
      String pathWithGz = path+".gz";                    // So if an uploaded file is not compressed, the existing compressed
      if(SPIFFS.exists(pathWithGz))                      // version of that file must be deleted (if it exists)
         SPIFFS.remove(pathWithGz);
    Serial.print("handleFileUpload Name: "); Serial.println(path);
    fsUploadFile = SPIFFS.open(path, "w");            // Open the file for writing in SPIFFS (create if it doesn't exist)
    path = String();
  } else if(upload.status == UPLOAD_FILE_WRITE){
    if(fsUploadFile)
      fsUploadFile.write(upload.buf, upload.currentSize); // Write the received bytes to the file
  } else if(upload.status == UPLOAD_FILE_END){
    if(fsUploadFile) {                                    // If the file was successfully created
      fsUploadFile.close();                               // Close the file again
      Serial.print("handleFileUpload Size: "); Serial.println(upload.totalSize);
      server.sendHeader("Location","/success.html");      // Redirect the client to the success page
      server.send(303);
    } else {
      server.send(500, "text/plain", "500: couldn't create file");
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t lenght) { // When a WebSocket message is received
  switch (type) {
    case WStype_DISCONNECTED:             // if the websocket is disconnected
      Serial.printf("[%u] Disconnected!\n", num);
      break;
    case WStype_CONNECTED: {              // if a new websocket connection is established
        IPAddress ip = webSocket.remoteIP(num);
        Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
        sendstart = false;                  // Turn rainbow off when a new connection is established
      break;
    case WStype_TEXT:                     // if new text data is received
      Serial.printf("[%u] get Text: %s\n", num, payload);
      if (payload[0] == '#') {            // we get RGB data
        uint32_t rpm = (uint32_t) strtol((const char *) &payload[1], NULL, 16);   // decode rgb data
        int R =          (rpm & 0x3FF);                      // B: bits  0-9
        Serial.print(R);
        setpointVariable = R;
      if (payload[0] == 'V') {
        sendvrate = true;
      else if (payload[0] == 'W') {
        sendvrate = false;
       if (payload[0] == 'L') {
        sendlinkage = true;
       else if(payload[0] == 'M') {
        sendvrate = false;
      else if (payload[0] == 'T') {                      // the browser sends an R when the rainbow effect is enabled
        sendstart = true;
      } else if (payload[0] == 'P') {                      // the browser sends an N when the rainbow effect is disabled
        sendstart = false;
      break;
/*__________________________________________________________HELPER_FUNCTIONS__________________________________________________________*/
String formatBytes(size_t bytes) { // convert sizes in bytes to KB and MB
  if (bytes < 1024) {
    return String(bytes) + "B";
  } else if (bytes < (1024 * 1024)) {
    return String(bytes / 1024.0) + "KB";
  } else if (bytes < (1024 * 1024 * 1024)) {
    return String(bytes / 1024.0 / 1024.0) + "MB";
String getContentType(String filename) { // determine the filetype of a given filename, based on the extension
  if (filename.endsWith(".html")) return "text/html";
  else if (filename.endsWith(".css")) return "text/css";
  else if (filename.endsWith(".js")) return "application/javascript";
  else if (filename.endsWith(".ico")) return "image/x-icon";
  else if (filename.endsWith(".gz")) return "application/x-gzip";
  return "text/plain";
By moose4621
#74110 So, I have made a little progress.
The number box now returns valid data. :)
So now I can set the required stepper motor rpm and then start the motor, stop the motor, but not restart or stop thereafter unless I reload the page. I have no idea why. :?
This is the JS.
Code: Select allvar sendStart;
var sendStop;
var sendlinkage;
var sendvrate;
var connection = new WebSocket('ws://'+location.hostname+':81/', ['arduino']);
connection.onopen = function () {
    connection.send('Connect ' + new Date());
connection.onerror = function (error) {
    console.log('WebSocket Error ', error);
connection.onmessage = function (e) {
    console.log('Server: ', e.data);
connection.onclose = function(){
    console.log('WebSocket connection closed');
function sendLinkage() {
   sendlinkage = ! sendlinkage;
    if(sendlinkage){
        connection.send("L");
     else {
        connection.send("M")
function sendVR() {
   sendvrate = ! sendvrate;
    if(sendvrate){
        connection.send("V");
     else {
        connection.send("W")
function sendRPM() {
    var R = (document.getElementById('R').value)*10;
    var rpm = R << 20
    var rpmstr = '#'+ rpm.toString(16);
    console.log('RPM: ' + rpmstr);
    connection.send(rpmstr);
function sendStart(){
    sendStart = true;
    if(sendStart){
        connection.send("T");
        sendStart = false;
function sendStop(){
    sendStop = true;
    if(sendStop){
        connection.send("P");
        sendStop = false;
This is the index.html
Code: Select all<!DOCTYPE html>
<html>
<head>
    <title>LED Control</title>
    <link href='main.css' rel='stylesheet' type='text/css'>
    <link rel="apple-touch-icon" sizes="180x180" href="/apple-touch-icon-180x180.png">
    <link rel="icon" type="image/png" sizes="144x144"  href="/favicon-144x144.png">
    <link rel="icon" type="image/png" sizes="48x48" href="/favicon.ico">
    <link rel="manifest" href="/manifest.json">
    <meta name="theme-color" content="#00878f">
    <meta content='width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0' name='viewport'>
    <script src="WebSocket.js" type="text/javascript"></script>
</head>
<body
style="background-color:Green;" style="text-color:Black;">
    <center>
        <header>
            <h1>Seeder Control</h1>
        </header>
        <div>
            <table>
                <tr>
                    <td style="width:200px; text-align: right">Linkage switch enabled: </td>
                    <td><input type="checkbox" id="L" value="linkage" size="10" onselect="sendLinkage();"> <a href="linkage.html" target="_top" name="Linkage" title="Linkage">?</a></td>
                </tr>
                <tr>
                    <td style="width:200px; text-align: right">Variable Rate enabled: </td>
                    <td><input type="checkbox" id="V" Value="0" size="10" onselect="sendVR();"> <a href="vrate.html" target="_top" name="Linkage" title="Vrate">?</a></td>
                </tr>
                <td style="width:200px; text-align: right">Motor RPM: </td>
                    <td>
  <input type="number" id="R" width="5" min="0.1" max="60" step="0.1" oninput="sendRPM();">(between 0.1 and 60):
  </td>
                <tr>
                    <td style="width:200px; text-align: right"><h1>Motor: </td>
                    <td><div class="centre"><button id="T"  type="button" onclick="sendStart();"style="background-color:yellowgreen"><h2>START</h2></button></div></td>
                    <td><div class="centre"><button id="P"  type="button" onclick="sendStop();"style="background-color:red"><h2>STOP</h2></button></div></td>
                </tr>
            </table>
        </div>
    </center>
</body>
</html>
And this is the arduino script.
#include <FS.h>
  delay(10);
bool sendlinkage;
bool sendvrate;
int hue = 0;
  stepper.runSpeed();
  if(sendstart) {
    stepper.setSpeed(setpointVariable/60*steps*microStep/10);
  else {
  Serial.print(ssid);
    delay(250);
    Serial.print('.');
  ArduinoOTA.begin();
    return true;
  return false;
  String path;
    path = String();
    if(fsUploadFile)
      server.send(303);
    } else {
  switch (type) {
      break;
      break;
        setpointVariable =          ((rpm >> 20) & 0x3FF);                       // B: bits  0-9
        sendvrate = true;
        sendvrate = false;
        sendlinkage = true;
        sendlinkage = false;
        sendstart = true;
        sendstart = false;
      break;
  if (bytes < 1024) {
By moose4621
#74160 I have solved a few of my html and javascript problems but here's show stopper for me. :roll:
I managed to get all of the stepper motor controls working remotely via a smart phone and the last step was to include a gps receiver to enable variable motor rpm according to ground speed. Using the TinyGPSPlus library which calls for SoftwareSerial, I found I had my old problem back again where the stepper rpm would pulse at about 1Hz in sinc with the led on the GPS receiver. :cry:
So back to basics. I merged the basic TinyGPSPlus Device example with the AccelStepper constant speed example.
Code: Select all#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 13, TXPin = 15;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
AccelStepper stepper(1, 4, 5); // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
void setup()
  ss.begin(GPSBaud);
  Serial.println(F("DeviceExample.ino"));
  Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  stepper.setMaxSpeed(1600);
   stepper.setSpeed(1000);
void loop()
   stepper.runSpeed();
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
And sure enough, the pulsing rpm is still there.
I have tried reading the gps on the hardware serial port Rx pin of the Wemos D1 mini but I don't seem to be able to read the GPS on that port so I don't know if this problem is strictly related to the SoftwareSerial.
Does anyone know how to get the GPS working on the hardware serial Rx port, (arduino pin1)? I realise I will probably lose serial comms but I can live with that if need be.
