When I open a 74880 baud serial monitor in Arduino IDE i get this message;
load 0x40100000, len 1856, room 16
tail 0
chksum 0x63
load 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : DOUT
SPI Flash Size & Map: 32Mbit(512KB+512KB)
jump to run user1 @ 1000
This is the diagram I followed to the letter:
I've tried powering with;
2xAA batteries
5v from Arduino Uno through a D1117V33 regulator
3.3v from Arduino Uno
I've tried using 10k and 1k resistors for the pull-ups, and without the resistor on GPIO15 pull down.
The two previous ESP12F has met their fate when flashing and with what I think was an unreliable power supply, sometimes dropping under 2.8v.
This time around I decided to just hook one up, fresh from the box and try to get it to boot. That's probably where I've should've started...
Could anyone point me in a direction on where to start to try to solve this?
