By cruunnerr
#75696 Hey guys,
first of all: sorry for my bad english. I try my very best ^^
i am a little newbie with the ESP8266 and Arduino. I play around with it since 2 weeks and i already got most things work :)
I build some boards for the ESP-01 with two relays. One relay on GPIO 2 and one on GPIO 0.
I connected it via MQTT with ioBroker. I can now switch the relay state with:
0 = Relay_1 off
1 = Relay_1 on
2 = Relay_2 off
3 = Relay_2 on
After this was working i installed the HomeKit Adapter in ioBroker to control the relays via Siri on the iPhone. Unfortunately the HomeKit App will just send a "true" or "false" to the ESP.
So i changed the Sketch a little bit and now i am able to control the first relay:
0 or false = Relay_1 off
1 or true = Relay_1 on
2 = Relay_2 off
3 = Relay_2 on
The problem is, that i can't find a solution for the second relay, because when i add the "true/false" to the second relays, Siri would always turn on/off both relays, as the ESP can't distinguish which relay was meant.
Is there a solution for the ESP to distinguish a simple true/false ?
I ope u guys can maybe help me :)
#include <PubSubClient.h>
#include <Bounce2.h>
#include <EEPROM.h>
#include <ESP8266WebServer.h>
const char* ssid = "...";
const char* password = "...";
const char* mqtt_server = "192.168.178.23";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* clientID = "ESP 2";
//const char* outTopic = "ESPout1";
const char* inTopic1 = "ESPin2.1";
const char* inTopic2 = "ESPin2.2";
#define RelaisPin 2  // Relais
int active_low = 1;
int relay_pin1 = 2;
int relay_pin2 = 0;
bool relayState1 = LOW;
bool relayState2 = LOW;
ESP8266WebServer server(80);        // Serverport  hier einstellen
int val = 0;
// Instantiate a Bounce object :
Bounce debouncer = Bounce();
void setup_wifi() {
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    for(int i = 0; i<500; i++){
      delay(1);
    Serial.print(".");
  Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
  String message;
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
    char c = (char)payload[i];
    message += c;
  if ((char)payload[0] == '0' || message == "false") {
    digitalWrite(relay_pin1, LOW);
    Serial.println("relay_pin1 -> LOW");
    relayState1 = LOW;
    EEPROM.write(0, relayState1);
    EEPROM.commit();
  } else if ((char)payload[0] == '1' || message == "true") {
    digitalWrite(relay_pin1, HIGH);
    Serial.println("relay_pin1 -> HIGH");
    relayState1 = LOW;
    EEPROM.commit();
  } else if ((char)payload[0] == '2') {
    digitalWrite(relay_pin2, LOW);
    Serial.println("relay_pin2 -> LOW");
    relayState2 = LOW;
    EEPROM.write(1, relayState2);
    EEPROM.commit();
  } else if ((char)payload[0] == '3') {
    digitalWrite(relay_pin2, HIGH);
    Serial.println("relay_pin2 -> HIGH");
    relayState2 = HIGH;
    EEPROM.commit();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(clientID)) {
      Serial.println("connected");
      client.subscribe(inTopic1);
      client.subscribe(inTopic2);
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      for(int i = 0; i<5000; i++){
//        extButton();
        delay(1);
  EEPROM.begin(512);              // Begin eeprom to store on/off state
  pinMode(relay_pin1, OUTPUT);     // Initialize the relay pin as an output
  pinMode(relay_pin2, OUTPUT);     // Initialize the relay pin as an output
  relayState1 = EEPROM.read(0);
  digitalWrite(relay_pin1,relayState1);
  relayState2 = EEPROM.read(1);
  digitalWrite(relay_pin2,relayState2);
  debouncer.interval(50);         // Input must be low for 50 ms
  setup_wifi();                   // Connect to wifi
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  client.loop();
