wifi.sta.setip({
ip = "192.168.1.5",
netmask = "255.255.254.0",
gateway = "192.168.0.2"
), I can only get connectivity when they're on either 192.168.1.1 or 192.168.1.2 (I have tested some random numbers, none worked, so I'm guessing these are the only two that work). I can ping the ESP on every IP address, and get a response perfectly. However, when I try to access the server (if that's even a server, I'm not yet very familiar with NodeMCU), I get no reply. Viewing the output in ESPlorer also gives me no activity at all on any IP outside the two working ones aforementioned.
The server is setup as follows:
srv=net.createServer(net.TCP)
srv:listen(43333, function(conn) It's very possible that I'm using an outdated / aged way of setting these things up, but I'm using a precompiled version of NodeMCU, of which I'm not sure which modules it contains. I'd love to build an up to date one myself, but without knowing which modules I need, that's gonna be a bit tricky.
Back to the main question however: Is there any reason that many IPs in the 192.168.1.* range won't allow me to use my server, but do allow me to ping the device?
