By Cem Kurt
#76202 Hello there,
There are some esp modules on the same wifi network but also too many connections on same network as well. (For example 10-15 different mobile phone or computer and 5 ESP modules on the same router.)
I can list connected devices on the network by their IP address, but how to know which one is ESP or any other device?
I want to define ESP modules on the network, is that possible? Is there a way to know that?
Thanks in advence :)
By btidey
#76224 Your router device list should list devices with mac addresses and ip. They will normally have a default name like ESP_112233 where the number is the last 3 bytes of the mac address.
You can use the router to allocate static ip addresses for their mac addresses which is useful if you want to ensure you can access a particular device at a fixed ip address. The router may aslo allow you to give static ips a more meaningful name.
Although the first 3 bytes of a mac address identify the vendor these are not the same for all ESP modules.
By Cem Kurt
#76225
schufti wrote:if you can also get their mac address, you can look for the first 3 bytes that should be the same for esp devices.
Thanks for your reply but their mac addresses is not same. :(
there are some tool to check the device vendor by their mac address but this way is not useful :(
