I'm on Mac OS X 10.14, using Arduino 1.8.5.
My ESP8266 board has an integrated (CP2102) USB to serial converter.
I'm trying to use my Esp8266 Esp-12e board with Arduino to make my first blink sketch work
Within Arduino I can pick the board "NodeMCU 1.0 (ESP-12E Module) however when I try to upload my sketch I get this error message
Arduino: 1.8.5 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 9600"
Build options changed, rebuilding all
Archiving built core (caching) in: /var/folders/8g/0k5j83g138v07k20mf01vb0c0000gn/T/arduino_cache_723312/core/core_esp8266_esp8266_nodemcuv2_CpuFrequency_80,VTable_flash,FlashSize_4M1M,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_9600_6d5f1add46e73b49a014734828dd4f54.a
Sketch uses 247880 bytes (23%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28016 bytes (34%) of dynamic memory, leaving 53904 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I have been through the documentation here: https://arduino-esp8266.readthedocs.io/en/2.4.1/faq/a01-espcomm_sync-failed.html
I've installed the USB to UART bridge driver from https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers and also rebooted my computer just in case.
What I believe isn't normal is the fact I can only see the port dev/cu.Bluetooth-Incoming-Port and nothing else
Just in case it might help, my NodeMCU has the blue led blinking when the board is connected via my USB cable.
Your feedback would be appreciated in order to help me troubleshoot this issue.
Thanks
