I am trying to interconnect a C# program that utilizes the TcpClient and Socket functionality, and an ESP8266 board with code from the ESP8266 Arduino Core and NodeMCU Firmware. I have tried different networks, ports, and even different programs with the same internal systems. The 2 codes I am using are written below.
C# code
void loadUI(){ //This is not the entire program but this is the section that communicates with the Node
enterIPLabel.Visible=false;
errorBox.Text="Connecting to Leader node";
tcpcom=new TcpClient(leadernode.ToString(),25565); //leadernode is the IP Address of the NodeMCU
tcpcom.Connect(leadernode.ToString(),25565); //just in case
while(!tcpcom.Connected);
tcpcom.Client.Send(System.Text.Encoding.ASCII.GetBytes("GetController"));
errorBox.Text="Awaiting Node Response";
while(tcpcom.Available<=0); //hopefully this should stop this method from executing until the response is made
//FILL IN CODE FOR RETURN STATEMENT
tabController.Visible=true;
NodeMap.Visible=true;
and the Arduino Code is:
String ConnectedMAC[8];
IPAddress ConnectedIP[8];
WiFiClient clientforcom;
WiFi.mode(WIFI_AP_STA);
Serial.begin(9600);
int f = WiFi.scanNetworks();
Serial.println("Scanning Networks");
delay(5000);
for (int n = 0; n < f; n++) {
Serial.println(WiFi.SSID(n));
WiFi.begin(ssidstring, passtring);
delay(2000);
delay(100);
Serial.print(".");
Serial.print("The IP of this node is: ");
MACManagement();
WiFiServer serverforclient(WiFi.localIP(), 25565);
while (!serverforclient.hasClient()) { //this does not work with Socket or delay is too long
delay(50);
Serial.println("Waiting for client");
clientforcom = serverforclient.available();
while (clientforcom.available() <= 0) {
delay(50);
Serial.println("Waiting for response");
String response = clientforcom.readString();
if (response.startsWith("GetController")) {
Serial.println("Sending String");
clientforcom.println("Returned String");
void MACManagement() {
unsigned char number_client;
struct station_info *stat_info;
struct ip_addr *IPaddress;
IPAddress address;
int i = 0;
number_client = wifi_softap_get_station_num();
stat_info = wifi_softap_get_station_info();
Serial.print(" Total Connected Clients are = ");
Serial.println(number_client);
while (stat_info != NULL) {
IPaddress = &stat_info->ip;
address = IPaddress->addr;
Serial.print("client= ");
Serial.print(i);
Serial.print(" IP adress is = ");
Serial.print((address));
ConnectedIP[i] = address;
Serial.print(" with MAC adress is = ");
Serial.print(stat_info->bssid[0], HEX); Serial.print(" ");
Serial.print(stat_info->bssid[1], HEX); Serial.print(" ");
Serial.print(stat_info->bssid[2], HEX); Serial.print(" ");
Serial.print(stat_info->bssid[3], HEX); Serial.print(" ");
Serial.print(stat_info->bssid[4], HEX); Serial.print(" ");
Serial.print(stat_info->bssid[5], HEX); Serial.print(" ");
ConnectedMAC[i] = String(stat_info->bssid[0], HEX) + ":" + String(stat_info->bssid[1], HEX) + ":" + String(stat_info->bssid[2], HEX) + ":" + String(stat_info->bssid[3], HEX) + ":" + String(stat_info->bssid[4], HEX) + ":" + String(stat_info->bssid[5], HEX);
stat_info = STAILQ_NEXT(stat_info, next);
i++;
}Whenever I have the ESP8266 board with the program at the "Waiting for client" stage, I open the C# code, and enter the IP Address into the leadernode variable (which I have confirmed is not broken). However, when communicating to the node, the C# program freezes and returns this error:
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it
I don't understand why the Node is refusing my connection. Am I missing something on the node code, or is my C# code for connection wrong?
I am completely lost, and any help would be extremely helpful.
Thanks.
