#include "DHT.h"
#include "ESP8266WiFi.h"
#include "ESP8266HTTPClient.h"
DHT dht;
WiFiClient client;
const char* MY_SSID = "********";
const char* MY_PWD = "********";
void setup()
Serial.begin(9600);
dht.setup(4);
void loop()
delay(10*1000);
Serial.print(dht.getHumidity());
Serial.print("\t");
Serial.print(dht.getTemperature());
Serial.print("\n");
WiFi.begin(MY_SSID, MY_PWD);
Serial.print("connecting to wifi...");
Serial.print(".");
Serial.println("\nconnected\n");
HTTPClient http;
String url = "http://mywebsite.co.uk/set_temp.php";
String data = "sid=1&temp=" + (String) dht.getTemperature() + "&hum=" + (String) dht.getHumidity();
http.begin(url);
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
int httpCode = http.POST(data);
Serial.println(httpCode);
Serial.println(payload);
http.end();
WiFi.disconnect();
server script...
<?php
$sid = $_GET['sid'];
$temp = $_GET['temp'];
$hum = $_GET['hum'];
$stats = $_SERVER['DOCUMENT_ROOT'] . '/stats.txt';
$handle = fopen($stats, 'a');
fwrite($handle, "sid: $sid \t temp: $temp \t humidity: $hum \n");
fwrite($handle, $_SERVER['REQUEST_URI']."\n");
fclose($handle);
exit;
If i do it via Chrome with...
http://mywebsite.co.uk/set_temp.php?sid ... =20&hum=50
it correctly adds
sid: 1 temp: 20 humidity: 50
/set_temp.php?sid=1&temp=20&hum=50
to the stats.txt file.
When done via the ESP8266 it just does this...
sid: temp: humidity:
/set_temp.php?
If I append the "data" to the "url" directly and pass that in http.begin it works, but only on my sever on my local network. On my website it timesout and then blocks my ip.
