I have used the esp8266 is multiple projects before. Mostly the ESP-03 and a couple with ESP-12.
Until now I have always avoided using GPIO0, 2 and 15.
For my current project, I need more IO pins than before and am forced to use 2 out of the 3 mentioned GPIOs.
I chose GPIO 0 and 2, since they both have to be pulled high on boot, and my application needs pullup resistors on the transistor bases. GPIO15 needs a pulldown resistor at boot, so it's incompatible with my pullup needs.
The wiring is:
GPIO0-----330K RES-------2N2222A base.
same for GPIO2.
In my current setup I do NOT have external pullups yet. But the Wemos module has a fixed 10K pullup on GPIO0.
Problem after soldering the whole thing: It won't boot the program with GPIO0 and 2 connected. When I cut those 2 wires, it worked. But now i'm missing my 2 crucial outputs, so any idea what could be the case?
Thanks in advance!
Istria
