I'm new on this forum and quite incompetent in electronic design as you'll understand reading below...
So I'm using ESP8266 module (with no external components) for an hobbyist project. Currently I know how to handle GPIO pins 0 and 15 to boot the ESP8266 and run my arduino code on it : i managed to use a double commutator to drive GPIO pins to VCC or GND depending of if I wish to upload code or execute it... Probably not the "academic way to do it, but it work.
But now I need to use the SPI controller to drive a LCD screen, and this is were I get in trouble: the SPI driver is using GPIO0 and GPIO2 in "function 1" mode. So how should I handle the wiring to keep UART, SPI, upload mode and normal mode ???
All of this is totally unclear in my mind, so any help would be appreciated !
Thanks,
Eric
