I'll do my best to provide the information that'll be helpful.
I'm using Platform IO, configured with a heltec_wifi_kit_32 board and the arduino framework. No pio libs installed.
When I build and upload the code, it starts the access point, and I can connect to it.
When I rebuild it (unchanged) and upload, and reconnect, it drops the esp into a reboot loop with a stack dump on the serial monitor.
If I change the ssid, and build and upload, it works once.
It seems like there is something I'm missing in my WiFi code, or there's a bug in the dhcp library when a client has an existing lease.
Any advice appreciated.
The code:
#include <WiFi.h>
#include <WebServer.h>
#include <DNSServer.h>
IPAddress ip(192, 168, 1, 1);
delay(3000);
WiFi.disconnect();
WiFi.mode(WIFI_OFF);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(ip, ip, IPAddress(255, 255, 255, 0));
WiFi.softAP("test");
void loop() { }
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5828
entry 0x400806ac
dhcps: send_offer>>udp_sendto result 0
Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x00000000 PS : 0x00060e30 A0 : 0x8010dfd9 A1 : 0x3ffb3b40
A2 : 0x3ffcb660 A3 : 0x3ffcbc0c A4 : 0x3ffbda68 A5 : 0x3ffbda48
A6 : 0x0201a8c0 A7 : 0x0c01a8c0 A8 : 0x8010de7c A9 : 0x3ffb3b00
A10 : 0x3ffcb670 A11 : 0x3ffcbc0c A12 : 0x3ffb3b4c A13 : 0x00000044
A14 : 0x00000001 A15 : 0x00000006 SAR : 0x00000010 EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000 LBEG : 0x4000c349 LEND : 0x4000c36b LCOUNT : 0x00000000
Backtrace: 0x00000000:0x3ffb3b40 0x4010dfd6:0x3ffb3b80 0x40116515:0x3ffb3ba0 0x4011b51d:0x3ffb3be0 0x40120642:0x3ffb3c00 0x4010e1a3:0x3ffb3c20 0x400886e1:0x3ffb3c50
#0 0x00000000:0x3ffb3b40 in ?? ??:0
#1 0x4010dfd6:0x3ffb3b80 in handle_dhcp at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/apps/dhcpserver/dhcpserver.c:1031
#2 0x40116515:0x3ffb3ba0 in udp_input at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/core/udp.c:401
#3 0x4011b51d:0x3ffb3be0 in ip4_input at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/core/ipv4/ip4.c:740
#4 0x40120642:0x3ffb3c00 in ethernet_input at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/netif/ethernet.c:184
#5 0x4010e1a3:0x3ffb3c20 in tcpip_thread at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/api/tcpip.c:483
#6 0x400886e1:0x3ffb3c50 in vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
