I am a newbie, working on a project to send a sensor data from Master to slave using two ESP8266 boards with ESP-NOW protocol. I succeeded in sending the data and displaying on serial monitor using the code shared by https://www.youtube.com/watch?v=grWkbdN2A1Q&t=766s.
Now I am trying to include "Adafruit_SSD1306" 128x32 display to show the status of my master on slave device. Both master and slave codes are running fine without any errors, but while receiving the data on slave, the device is getting restarted and I found that the ESP8266 is restarting while executing the "SSD130" display command lines written in the function "SenderStatus()".
I could run the device by removing following lines (for example) from the function
if(atoi(value)==500)
Serial.println("Status 1 Ready");
/* display.clearDisplay (); // clear display
display.setCursor(10,13);
display.setTextSize(1);
display.setTextColor (WHITE);
display.print ("Status 1 Ready");
display.display ();//
delay(2000);
And i tried to add the "SSD1306 allocation" commands again in the function just before "clear display" command, but no luck. How can I fix this to display the status on slave device using SSD1306.
Master:
#include<Wire.h>
extern "C" {
#include <espnow.h>
// this is the MAC Address of the slave which receives the data
uint8_t mac[] = {0xDA, 0xBC, 0xC2, 0x11, 0x11, 0x11};
#define WIFI_CHANNEL 4
// must match the slave struct
struct __attribute__((packed))
DataStruct {
char text[15];
DataStruct Data;
Wire.begin(4,5);
WiFi.mode(WIFI_STA); // Station mode for esp-now controller
WiFi.disconnect();
Serial.printf("This mac: %s, ", WiFi.macAddress().c_str());
Serial.printf("slave mac: %02x%02x%02x%02x%02x%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
Serial.printf(", channel: %i\n", WIFI_CHANNEL);
if (esp_now_init() != 0)
Serial.println("*** ESP_Now initialization failed");
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
esp_now_add_peer(mac, ESP_NOW_ROLE_SLAVE, WIFI_CHANNEL, NULL, 0);
strcpy(Data.text,"");
delay(2000);
strcpy(Data.text,"500"); //status 1
sendData();
delay(2000);
strcpy(Data.text,"600"); //status 2
sendData();
delay(2000);
strcpy(Data.text,"700"); //status 3
sendData();
delay(2000);
strcpy(Data.text,"800"); //status 4
sendData();
delay(2000);
Serial.println("Setup finished");
ReadSensor();
sendData();
void ReadSensor()
char S_text[10];
double sensor=380.21; // dummy sensor value
dtostrf(sensor, 3, 2, S_text);
strcpy(Data.text,S_text);
void sendData()
uint8_t bs[sizeof(Data)];
memcpy(bs, &Data, sizeof(Data));
esp_now_send(NULL, bs, sizeof(Data));
Serial.println(Data.text);
Slave:
extern "C" {
#include <espnow.h>
#include <user_interface.h>
//==============Display=============
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
void initVariant() {
WiFi.mode(WIFI_AP);
wifi_set_macaddr(SOFTAP_IF, &mac[0]);
// must match the controller struct
DataStruct {
char text[15];
DataStruct myData;
int8_t flag=0;
Serial.begin(115200); Serial.println();
Serial.println("Starting....");
Serial.print("AP mac: "); Serial.println(WiFi.softAPmacAddress());
Serial.print("STA mac: "); Serial.println(WiFi.macAddress());
//display
Wire.begin(4,5);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
delay(2000); // Pause for 2 seconds
display.setCursor(20,13);
display.print ("Starting....");
delay(2000);
display.setCursor (12,8); // position the cursor
display.setTextSize (2); // medium size font
display.setTextColor (WHITE); // white is not default !
display.print ("Hello");
delay(2000);
//ESP Initialize
if (esp_now_init()!=0) {
Serial.println("*** ESP_Now init failed");
while(true) {};
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb(receiveCallBackFunction);
Serial.println("End of setup - waiting for messages");
void receiveCallBackFunction(uint8_t *senderMac, uint8_t *incomingData, uint8_t len) {
memcpy(&myData, incomingData, sizeof(myData));
if(flag<=3)
SenderStatus();
Serial.println(myData.text);
void SenderStatus()
char value[15];
strcpy(value,myData.text);
display.clearDisplay (); // clear display (restarting while executing these line)
delay(2000);
else if(atoi(value)==600)
Serial.println("Status 2 Ready");
display.setCursor(18,13);
display.print ("Status 2 Ready");
delay(2000);
else if(atoi(value)==700)
Serial.println("Status 3 Ready");
display.print ("Status 3 Ready");
delay(2000);
else if(atoi(value)==800)
Serial.println("Status 4 Ready");
display.print ("Status 4 Ready");
delay(2000);
Serial.println("Receiving Data");
display.print ("Receiving Data");
flag++;
