PS. You mean WS2812B LEDs? If Yes, You will need voltage translator too (from 3.3 to 5V).
Connecting a resistor from 3V to TX may allow the board to boot up properly, but it's not a recommended solution as it may not be reliable and could potentially cause damage to the board.
esp8266_dude wrote:You can safely use Pull-Up.
Thank you, when you say that i can safely use Pull-Up do you mean that what i did is a Pull-Up? or Pull'up is a different circuit?
About the regulator i already tested the strip and it work even without the regulator thanks
