Hi,
I'm using NodeMCU for a project and Arduino 1.8.8. I want to convert a string to char Array. The code and output are as follows.
code:
char ssid[] = "";
char pass[] = "";
Serial.begin(9600);
String answer = "ssid:Moto G (4) 6788aesrhtd5@#$; pass:error$34556jjhjv24";
extract(answer);
Serial.println(ssid);
Serial.println(pass);
void extract(String value) {
String t_ssid = "";
String t_pass = "";
int flag = 0;
int len = value.length();
for (int i = 0; i < len ; i++) {
if (value.charAt(i) == ';')
flag = i;
t_ssid = value.substring(5, flag);
t_pass = value.substring(flag + 7, len);
Serial.print(ssid);
Serial.println(".");
Serial.print(pass);
Serial.println(t_ssid);
Serial.println(t_pass);
for (int i = 0; i < t_ssid.length(); i++)
ssid[i] = t_ssid.charAt(i);
for (int j = 0; j < t_pass.length(); j++)
pass[j] = t_pass.charAt(j);
Result:
Screenshot attached herewith. (I've pressed the reset button once.)
Expected Result:
error$34556jjhjv24
error$34556jjhjv24
I'm pretty much unsure as of why the result is not as expected and also why these ghostly characters are showing up in the serial monitor.
Any help is highly appreciated...
