Have questions about FETS, transistors, measurement, power supplies, or anything else electrical?
By Luxfire
#82805 Hello Guys,
i cant show anything on lcd by i2c. my conections: SCL -->D1 SDA -->D2 .
There is some data flow between nodemcu and lcd, i've checked it with osciloscope. nodemcu also can dim the backlight of lcd and turn it on again, so i think it works? but i can't achieve showing any text. also contrast was checked with multimeter if the potentiometer works. Have You some ideas what could have gone wrong?
Code: Select all#include <LiquidCrystal_I2C.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
//Use predefined PINS consts
Wire.begin();
lcd.begin();
lcd.noBacklight();
lcd.home();
delay(200);
lcd.print("Hello, NodeMCU");
lcd.backlight();
void loop() { // do nothing here
By Luxfire
#82842 i've got PCF8574T chip on LCD. Before this code i also uploaded i2c scanner, also if i change address from 0x27 to 0x17(just random address) lcd backlight won't off/on anymore. so i'm sure(?) that 0x27 is my lcd address.
By QuickFix
#82882 Just a wild idea: have you verified that the LCD-library you're using is ESP8266 compatible?
Not all (in fact most) libraries for hardware is written with the Arduino (ATMEGA) in mind and are not 100% compatible with the NodeMCU (ESP8266).
