Moderator: eriksl
eriksl wrote:The broadcom SoC in the Raspberry is fundamentally another thing, it cannot be compared to the ESP8266. It will probably run happily at 800 MHz to start with and maybe reach up 1.6 GHz.
No, i mean the microcontroller, no the microprocessor, check the Raspberry Pi Pico, is a silicon maded by Rasbperry Fundation itself. Here the specs:
- 21 mm × 51 mm form factor
RP2040 microcontroller chip designed by Raspberry Pi in the UK
Dual-core Arm Cortex-M0+ processor, flexible clock running up to 133 MHz
264KB on-chip SRAM
2MB on-board QSPI Flash
26 multifunction GPIO pins, including 3 analogue inputs
2 × UART, 2 × SPI controllers, 2 × I2C controllers, 16 × PWM channels
1 × USB 1.1 controller and PHY, with host and device support
8 × Programmable I/O (PIO) state machines for custom peripheral support
Supported input power 1.8–5.5V DC
Operating temperature -20°C to +85°C
Castellated module allows soldering direct to carrier boards
Drag-and-drop programming using mass storage over USB
Low-power sleep and dormant modes
Accurate on-chip clock
Temperature sensor
Accelerated integer and floating-point libraries on-chip
