By hwiguna
#4761
hwiguna wrote:
hwiguna wrote:Alas, when I run a webserver on the ESP. The I/O flicker returns, and shift register stopped working :-(
This appears to have been error in my lua code. :oops:
I've since been able to get the ESP-03 drive a shift register AND respond to web requests.
Here is the code and more related videos here: viewtopic.php?f=19&t=845
By Markus Gritsch
#4794 Hmm, I cannot confirm any GPIO flickering. Here is what it looks like when switching from 0 to 1 when powering from a 3.3 V regulator:
When powering from the 3.3 V of the FTDI adapter (which cannot provide enough current) I added a 470 uF capacitor. This is how it looks in this case:
Not as good, but still ok.
By Markus Gritsch
#4816 Hi Hari,
from watching your YouTube videos, I think I know what's causing the problems in your circuit: You are using a 3.3 V regulator, but you have to add capacitors before and after the regulator to give it something to work with. Typically you would add 1 uF from the regulator input to ground and 1 uF from the regulator output to ground. Look into the regulators datasheet. It will contain some application circuit showing these caps.
Have fun,
Markus
