By ssylca
#11413 Several times I got a bad 'Save to ESP' using ESPlorer, and after that couldn't remove the file using the Lua command. I had to re-flash Lua with NodeMCU Firmware Programmer to again get control of the ESP8266. Any idea why this happen?
Thanks
By raz123
#11485 I've gotten this a few times as well. I'm trying to come up with a way to reliably reproduce this issue so that the concerned developers can fix it. If you manage to do it, please post here.
By andrew melvin
#11489 I've had this as well. Im wondering if it when you've run out of space.
I also had to Reflash.... Untill I discovered.
file.format()
For me it cleaned it all up and I just had to re write all the files. Faster than a reflash!
By ssylca
#11541 I tried the file.format() command and just got this message ..... attempt to call field 'format' (a nil value)
The file didn't get erased!
Back to a re-flash!
S.
