I've just tried your code, sending to thingspeak is ok but the values (read and sent) are wrong
Humidity: 70.4%
Temperature: 45.2 deg C
Temperature: 113.36 deg F
I've checked the sensor by reading it with an arduino and I got 21.4°C and 44% humidity (checked with another Oregon sensor).
I've also tried your code without sensor attached and I got the following:
Humidity: -0.1%
Temperature: -3276.7 deg C
Temperature: -5866.06 deg F
So it seems to read something but not in the right way, would you have any idea of the problem?
I'm running build 20150213.
Thank you in advance for your help!
Kind regards.
This program might work better, do not forget to reset after uploading !!! You can also try to compile files using node.compile (), it can be. But it does not solve the problem of hardware.
-- name BPclient03.lua
-- Demo thingspeak.com client with sensor DHT11/22
-- Tested with Lua NodeMCU 0.9.5 build 20150213
-- 1. Flash Lua NodeMCU to ESP module.
-- 2. Set in program BPclient03.lua humidity sensor type. This is parameter typeSensor="dht11" or "dht22".
-- 3. Set in program BPclient03.lua your thingspeak.com write API key
-- 4. You can rename the program BPclient03.lua to init.lua
-- 5. Load program BPclient03.lua and dht.lua to ESP8266 with LuaLoader
-- 6. HW reset module !!!
-- 7. Login module to your AP - wifi.setmode(wifi.STATION),wifi.sta.config("yourSSID","yourPASSWORD") from console !!!
-- 8. Run program BPclient03.lua - dofile(BPclient03.lua)
-- 9. The sensor is repeatedly read and data are send to api.thingspeak.com every 15s,
-- It is minimal period for data send to api.thingspeak.com
-- The author of the program module dht.lua for reading DHT sensor is Javier Yanez
-- The author of the http client part is Peter Jennings
sensorType="dht11" -- set sensor type dht11 or dht22
WRITEKEY="EMZHRBDWJBZI2MV0" -- set your thingspeak.com key
timup=tmr.now()
PIN = 4 -- data pin, GPIO2
humi=0
temp=0
fare=0
chck=0
gslp=0
--load DHT module for read sensor
function ReadDHT()
dht=require("dht")
dht.read(PIN)
chck=1
h=dht.getHumidity()
t=dht.getTemperature()
if h==nil then h=0 chck=0 end
if sensorType=="dht11"then
humi=h/256
temp=t/256
humi=h/10
temp=t/10
fare=(temp*9/5+32)
print("Humidity: "..humi.."%")
print("Temperature: "..temp.." deg C")
print("Temperature: "..fare.." deg F")
-- release module
dht=nil
package.loaded["dht"]=nil
-- send to https://api.thingspeak.com
function SendTS()
conn = nil
conn = net.createConnection(net.TCP, 0)
conn:on("receive", function(conn, payload)success = true print(payload)end)
conn:on("connection",
print("Connected")
conn:send('GET /update?key='..WRITEKEY..'&field1='..humi..'&field2='..temp..'&field3='..chck..'HTTP/1.1\r\n'..
'Host: api.thingspeak.com\r\nAccept: */*\r\nUser-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n\r\n')
end)
conn:on("disconnection",
print('Disconnected')
end)
conn:connect(80,'184.106.153.149')
tmr.alarm(1,15000, 1,
function()
if wifi.sta.getip()~=nil
then ReadDHT()SendTS()
end)
-- name dht.lua
-- DHT module for ESP8266 with nodeMCU floating point
-- Written by Javier Yanez
-- but based on a script of Pigs Fly from ESP8266.com forum
-- MIT license, http://opensource.org/licenses/MIT
local moduleName = ...
local M = {}
_G[moduleName] = M
local humidity
local temperature
function M.read(pin)
local checksum
local checksumTest
humidity = 0
temperature = 0
checksum = 0
-- Use Markus Gritsch trick to speed up read/write on GPIO
local gpio_read = gpio.read
local bitStream = {}
for j = 1, 40, 1 do
bitStream[j] = 0
local bitlength = 0
-- Step 1: send out start signal to DHT22
gpio.mode(pin, gpio.OUTPUT)
gpio.write(pin, gpio.HIGH)
tmr.delay(100)
gpio.write(pin, gpio.LOW)
tmr.delay(20000)
gpio.mode(pin, gpio.INPUT)
-- Step 2: DHT22 send response signal
-- bus will always let up eventually, don't bother with timeout
while (gpio_read(pin) == 0 ) do end
local c=0
while (gpio_read(pin) == 1 and c < 500) do c = c + 1 end
c=0
-- Step 3: DHT22 send data
for j = 1, 40, 1 do
while (gpio_read(pin) == 1 and bitlength < 10 ) do
bitlength = bitlength + 1
bitStream[j] = bitlength
bitlength = 0
while (gpio_read(pin) == 0) do end
--DHT data acquired, process.
for i = 1, 16, 1 do
if (bitStream[i] > 3) then
humidity = humidity + 2 ^ (16 - i)
if (bitStream[i + 16] > 3) then
temperature = temperature + 2 ^ (16 - i)
for i = 1, 8, 1 do
if (bitStream[i + 32] > 3) then
checksum = checksum + 2 ^ (8 - i)
checksumTest = (bit.band(humidity, 0xFF) + bit.rshift(humidity, 8) + bit.band(temperature, 0xFF) + bit.rshift(temperature, 8))
checksumTest = bit.band(checksumTest, 0xFF)
if temperature > 0x8000 then
-- convert to negative format
temperature = -(temperature - 0x8000)
-- conditions compatible con float point and integer
if (checksumTest - checksum >= 1) or (checksum - checksumTest >= 1) then
humidity = nil
function M.getTemperature()
return temperature
function M.getHumidity()
return humidity
return M
Here you can see how erroneous values are read from the sensor DHT11. It is an interference problem, which I do not currently suppress. In reality, temperature is stabile about 23 grades. ESP8266 is periodic awakening from deep sleep and loged in.
Great! One night of testing (sampling each minute instead of 15s) and it seems ok!
I'll continue the test for a few days and will post result here...
Keep up the good work!
