-- DHT22/11 module for ESP8266 with nodeMCU
-- Written by Javier Yanez
-- but based on a script of Pigs Fly from ESP8266.com forum
-- MIT license, http://opensource.org/licenses/MIT
local moduleName = ...
local M = {}
_G[moduleName] = M
local humidity
local temperature
local checksum
local checksumTest
local minCountForLow = 1
function M.read(pin)
humidity = 0
temperature = 0
checksum = 0
-- Use Markus Gritsch trick to speed up read/write on GPIO
gpio_read = gpio.read
gpio_write = gpio.write
bitStream = {}
for j = 1, 40, 1 do
bitStream[j] = 0
bitlength = 0
-- Step 1: send out start signal to DHT
gpio.mode(pin, gpio.OUTPUT)
--MCU needs to pull data line down >18mS to signal DHT response
gpio.write(pin, gpio.LOW)
tmr.delay(20000)
--MCU awaiting response
gpio.mode(pin, gpio.INPUT)
-- Step 2: DHT send response signal
-- MCU looks for DHT to respond with 80uS low on the data line
while (gpio_read(pin) == 0 ) do end
-- Followed by a 80uS high on the data line
while (gpio_read(pin) == 1) do end
-- MCU looks for DHT to indicate start bit by pulling data line down for 50uS
-- Step 3: DHT send data (40 bits)
for j = 1, 40, 1 do
while (gpio_read(pin) == 1 and bitlength < 3 ) do
bitlength = bitlength + 1
bitStream[j] = bitlength
bitlength = 0
-- MCU looks for DHT to indicate start of next bit by pulling data line down for 50uS
while (gpio_read(pin) == 0) do end
--DHT data acquired, process.
for i = 1, 16, 1 do
if (bitStream[i + 0] > minCountForLow) then
-- Add up all the "high" bit postion values
humidity = humidity + 2 ^ (16 - i)
if (bitStream[i + 16] > minCountForLow) then
temperature = temperature + 2 ^ (16 - i)
for i = 1, 8, 1 do
if (bitStream[i + 32] > minCountForLow) then
checksum = checksum + 2 ^ (8 - i)
checksumTest=((humidity-humidity%256)/256+humidity%256+(temperature-temperature%256)/256+temperature%256)%256
if temperature > 0x8000 then
-- convert to negative format
temperature = -(temperature - 0x8000)
if tostring(checksum) ~= tostring(checksumTest) then
humidity = -1
function M.getTemperature()
return temperature
function M.getHumidity()
return humidity
return M
This is my first post. I'm just starting to get my head around the ESP8266, but unfortunately I cannot get this to work I keep getting negative values. -0.1 for humidity and -3276.7 for temperature. Does anyone have a wiring diagram or a photo, video I can follow just to double check I've wired the device up correctly please. I'm using the latest nodemcu_20150212.bin. The webpage is working fine, its just the results I'm getting back from the DHT22 unit are completely wrong. Any suggestions anyone. Many thanks!!!!!
Please help i'm getting crazy about it
1. Is your sensor really connected to GPIO2 ?
2. Is sensor properly connected to ground?
3. Is your terminals wiring okay?
Save test program wots.lua and modul testdht.lua
Load it to esp8266 and run wots.lua.
Bring result.
Then we can talk of an additional cases.
This is proper communication with DHT11. DHT22 is very similar.
dofile("wots.lua")
checksum 58
checksumTest 58
humidity - timing of bits 0 1 5 1 1 5 1 4 1 1 1 1 1 1 1 1
temperat - timing of bits 1 1 1 5 1 5 1 4 1 1 1 1 1 1 1 1
checksum - timing of bits 1 1 5 5 5 1 5 1
Humidity: 37%
Temperature: 21 deg C
And here the sensor is disconnected .
dofile("wots.lua")
checksum 255
checksumTest 252
humidity - timing of bits 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10
temperat - timing of bits 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10
checksum - timing of bits 10 10 10 10 10 10 10 10
Humidity: 0%
Temperature: -127.99609375 deg C
