My problem is that, when I read the temperature I'm unable to send the data to thingspeak but if I comment all the part that reads the data from the sensor and insert a fake temperature data, the connection with thingspeak went good.
I've tried different codes with different types of boards (ESP-01 and ESP-12) but the problem remain the same. Now, i'm using the following configuration
ds18b20 connected as shown here http://mo.mosfet.co/2015/03/08/ESP8266-temperature-sensor.html
Connect the pull-up resistor between VCC and DQ (middle pin) on the DS18B20
Connect pin 1 (GND) and pin 3 (Vdd) on the DS18B20 to common ground.
Connect DQ to GPIO2 on the ESP
Connect TX/RX to your 3.3V serial cable
and using the following code:
function sendData(temp)
t1 = temp / 10000
t2 = (temp >= 0 and temp % 10000) or (10000 - temp % 10000)
print("Temp:"..t1 .. "."..string.format("%04d", t2).." C\n")
-- conection to thingspeak.com
print("Sending data to thingspeak.com")
conn=net.createConnection(net.TCP, 0)
conn:on("receive", function(conn, payload)
print(payload)
conn:close()
end)
-- api.thingspeak.com 184.106.153.149
conn:connect(80,'184.106.153.149')
str = "GET /update?key=<key>&field1="..t1.."."..string.format("%04d", t2).." HTTP/1.1\r\nHost: api.thingspeak.com\r\n".."Connection: close\r\nAccept: */*\r\n\r\n"
conn:send(str)
function work()
sendData(31000)
function work1()
t = require("ds18b20")
gpio2 = 4
t.setup(gpio2)
addrs = t.addrs()
if (addrs ~= nil) then
print("Total DS18B20 sensors: "..table.getn(addrs))
-- Just read temperature
temp = t.read()
print("Temperature: "..t.read().."°C")
-- Don't forget to release it after use
t = nil
ds18b20 = nil
package.loaded["ds18b20"]=nil
sendData(temp)
wifi.setmode(wifi.STATION)
print("******* 5 seconds delay *******");
tmr.alarm(2,5000,0, function()
wifi.sta.config("SSID","password")
wifi.sta.connect()
print("DHCP delay (5 s.)...");
tmr.delay(5000000)
work1()
tmr.alarm(0, 30000, 1, function() work1() end )
end)
If I use the "work" function all works perfect, but if I use the "work1" function the connection does not complete and the data is not saved.
Please, help me
Thanks
Just for information it was the sendData function that was not coded properly. Using the procedure sugested in this post http://www.esp8266.com/viewtopic.php?f=19&t=834&start=30#p29765 solved the issue.
Bye!
