By zhivko
#11979 Is it possible to fetch a text that user entered in textbox to lua variable?
I have 2 esp8266, one with relay and another with temperature sensor. I would like to enter temperature when relay triggers - and I want to this data to be captured from http web server page.
Is this possible somehow?
By zhivko
#12006
zhivko wrote:Is it possible to fetch a text that user entered in textbox to lua variable?
Seems to me that clever heads already did it with following code (taken from http://randomnerdtutorials.com/esp8266-web-server/) - with following lua code:
Code: Select allsrv:listen(80,function(conn)
    conn:on("receive", function(client,request)
        local buf = "";
        local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
        if(method == nil)then
            _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
        local _GET = {}
        if (vars ~= nil)then
            for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
                _GET[k] = v
By Gadgit
#12017 Just to give my experience for anyone also trying this.
Not yet exactly sure why but none of these different examples worked for me except Jankop's viewtopic.php?p=11189#p11189
I'm on NodeMCU 0.9.5 build 20150213 using a DHT11 on this ESP8266 SDK board: http://scottsnowden.co.uk/?p=393
I think it is something to do with the timing, but also the lines which interpret the bitStream are different in Jankop's version:
Code: Select all
for i = 1, 16, 1 do
   if (bitStream[i] > 3) then
      humidity = humidity + 2 ^ (16 - i)
    if (bitStream[i + 16] > 3) then
      temperature = temperature + 2 ^ (16 - i)
which works vs:
Code: Select all  --DHT data acquired, process.
  for i = 1, 16, 1 do
    if (bitStream[i + 0] > 2) then
    if (bitStream[i + 16] > 2) then
which doesn't. The only difference I can see is that Jankop starts 1 bit later. I can't understand why one works for some people and not for others
