Here. I saw in source code.
Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
Explore... Chat... Share...
cdrwolfe wrote:I'm beginning to wonder if this is possible at all using lua.
For the life of me I can't get the chip to correctly control the gpio pins. With the DHT22 connected it is always set as high, calling gpio.write(pin, gpio.LOW) does nothing .
If anyone else has any luck feel free to post it .
Regards
Cdr
pin = 4;
-- Initiliase bit data array
bitData = {}
gpio.mode(pin, gpio.OUTPUT)
tmr.delay(20000)
gpio.write(pin, 1)
gpio.mode(pin, gpio.INPUT)
