tuanpm wrote:UPDATE: 2015-Jan-17: while waiting NodeMcu published, you can try to play with it here: https://github.com/tuanpmt/nodemcu-firmware
UPDATE: 2015-Jan-18: New source/api more reliable: https://github.com/nodemcu/nodemcu-firmware/tree/mqtt
Hello,
Here are the results of my attempt to add mqtt stack to net module of nodemcu:
Port from Native MQTT client for ESP8266:
viewtopic.php?f=6&t=1031
Firmware:
Code for test:Code: Select all-- init mqtt client with keepalive timer 120sec
m = mqtt.Client("clientid", 120, "user", "password")
-- setup Last Will and Testament (optional)
-- Broker will publish a message with qos = 0, retain = 0, data = "offline"
-- to topic "/lwt" if client don't send keepalive packet
m:lwt("/lwt", "offline", 0, 0)
m:on("connect", function(con) print ("connected") end)
m:on("offline", function(con) print ("offline") end)
-- on publish message receive event
m:on("message", function(conn, topic, data)
print(topic .. ":" )
if data ~= nil then
print(data)
end)
-- for secure: m:connect("192.168.11.118", 1880, 1)
m:connect("192.168.11.118", 1880, 0, function(conn) print("connected") end)
-- subscribe topic with qos = 0
m:subscribe("/topic",0, function(conn) print("subscribe success") end)
-- publish a message with data = hello, QoS = 0, retain = 0
m:publish("/topic","hello",0,0, function(conn) print("sent") end)
m:close();
-- you can call m:connect again
Example applicationCode: Select allm = mqtt.Client(wifi.sta.getmac(), 120, "user", "password")
m:lwt("/lwt", wifi.sta.getmac(), 0, 0)
print ("reconnecting...")
print(node.heap())
tmr.alarm(1, 10000, 0, function()
m:connect("192.168.11.102", 1880, 0)
end)
end)
if data ~= nil then
print(data)
end)
tmr.alarm(0, 1000, 1, function()
if wifi.sta.status() == 5 then
tmr.stop(0)
m:connect("192.168.11.102", 1880, 0, function(conn)
print("connected")
end)
end)
end)
Regards
Hi tuanpm. Thank so much for your contribution and I need your help now.
My ESP8266-01 module was still running normal before but now it's always restart continuously after I did tried the test as your guide. I used LuaUploader tool as following:
1. First saving init.lua to the module like that:
wifi.setmode(wifi.STATION)
wifi.sta.config ( "mySSID" , "myPass" )
print(wifi.sta.getip())
dofile ( "main.lua")
2. Second saving main.lua to the module. The code as the same as your Example Application.
After that the module continuous restart. I just get the respond like that:
ö,38ÿD@
cÀâgFàȈ÷¨Hø
NodeMCU 0.9.5 build 20150318 powered by Lua 5.1.4
nil
I also tried re-fash by the nodemcu flash tool but it can not flash now. Is that possible my module is broken?
Please let me know if you have any advice. Thanks
