it awakes at the end of the minute no interrupts
Edit : BTW i'm trying to wake the module up from the GPIO 4 as in the example i sent
Explore... Chat... Share...
cendev wrote:Why it had to be a minute? It took so long sorry about that.. tried some more combinations
it awakes at the end of the minute no interruptssame result for lua that i compiled :/
Edit : BTW i'm trying to wake the module up from the GPIO 4 as in the example i sentit's pin 4 that i must try right?
alonewolfx2 wrote:cendev wrote:Why it had to be a minute? It took so long sorry about that.. tried some more combinations
gpio_pin_wakeup_enable(GPIO_ID_PIN(4), GPIO_PIN_INTR_HILEVEL);
cendev wrote:alonewolfx2 wrote:cendev wrote:Why it had to be a minute? It took so long sorry about that.. tried some more combinations
one last thingpin 4 is ok, can you compile it again with pin 4 enabled and system_deep_sleep(0) instead of a min?
