Left for archival purposes.
By kadamski
#9269 From what I've read this dns suffix is the same functionality as Unix "search XX" in resolv.conf. So if I understand this correctly, it should only change how local resolver works and should not change other machines ability to resolve hostnames.
The compilation error is strange. Either you already compiled all the objects (*.o files) or it did not even try to build them. It looks like $(OBJS) was not defined. Could you try to edit the Makefile and make put all the objects in one line, without those "\" at the end of line? Something like this (everything in one line):
Code: Select allOBJS = src/api/api_lib.o src/api/api_msg.o src/api/err.o src/api/netbuf.o src/api/netdb.o src/api/netifapi.o src/api/sockets.o src/api/tcpip.o src/core/ipv4/autoip.o src/core/ipv4/icmp.o src/core/ipv4/igmp.o src/core/ipv4/inet.o src/core/ipv4/inet_chksum.o src/core/ipv4/ip.o src/core/ipv4/ip_addr.o src/core/ipv4/ip_frag.o src/core/dhcp.o src/core/dns.o src/core/def.o src/core/init.o src/core/netif.o src/core/mem.o src/core/memp.o src/core/pbuf.o src/core/raw.o src/core/stats.o src/core/sys.o src/core/tcp.o src/core/tcp_in.o src/core/tcp_out.o src/core/timers.o src/core/udp.o src/netif/etharp.o espressif/espconn.o espressif/espconn_tcp.o espressif/espconn_udp.o espressif/sys_arch.o espressif/netio.o espressif/dhcpserver.o espressif/ping.o our/eagle_lwip_if.o
