void gpio_pin_wakeup_enable(uint32 i, GPIO_INT_TYPE intr_state);
It is also defined in the loader
eagle.rom.addr.v6.ld:PROVIDE ( gpio_pin_wakeup_enable = 0x40004e90 );
Explore... Chat... Share...
alonewolfx2 wrote:where did you saw this function? if it exist i want to try but i have esp-01 and direnc.net esp-07 modules out of the stockif it is working i can implement in to the lua
Also i saw this on bbs :
gpio_pin_wakeup_enable(GPIO_ID_PIN(4), GPIO_PIN_INTR_HILEVEL);
I guess this time it's more clear
joe wrote:You can find the definition of it in include/gpio.h of the sdk
