Left for archival purposes.
By Aonko
#12263 You are correct Markus Gritsch, the first time I flashed the firmware with a cp2102 instead of a knockoff ftdi board it worked. Thanks for the troubleshooting help.
By kalya
#12617
Markus Gritsch wrote:You are wrong. It is only disabled in the master branch. The dev branch, from which the travis-ci builds are made, has it activated. Your problem is probably that you use write() instead of writergb() as documented at the bottom of this page: https://github.com/nodemcu/nodemcu-firmware/tree/dev
To sum it up:
Use these binaries: https://github.com/nodemcu/nodemcu-firm ... ses/latest
Use this function: ws2812.writergb
Have fun,
Markus
Which of these ?
float , integer or both ?
By Speshal
#13288 Hi I wondered if someone could help me with the original "wifi-lights" example.
I have flashed both bin files 0x00000 and 0x10000 via ESP flasher and loaded the server.lua file and I've also uploaded the index.html file through Esplorer, but I get this error?
Code: Select all> FILE="index.html" file.remove(FILE) file.open(FILE,"w+") uart.setup(0,115200,8,0,1,0)
--Done--
> dofile("index.html")
index.html:1: unexpected symbol near '<'
I see nothing on IP 192.168.4.1? I hope someone can help as I'm excited to get this working
