Below an example for io.read:
io.write('Hello, what is your name? ')
local name = io.read()
io.write('Nice to meet you, ', name, '!\n')
Explore... Chat... Share...
node.key()
Description
define button function, button is connected to GPIO16.
node.key(8) -- key found at GPIO0
node.led(8) -- LED found at GPIO0
alonewolfx2 wrote:Can you add driver for ds18b20 temprature sensor. driver is here.
https://github.com/pilotniq/esp8266-frankenstein/commit/ff4d8c4124f9ef5a383bb29c69a80f5ab5c5e48d
JoHannes wrote:Yes, ds1820 and dht11/22 would be really cool!
