scargill wrote:Ernie - I don't agree. That is a function call - I don't think there should be a space where you suggest. If it IS necessary surely that's a bug?
All -
I've done some more tests.
In each case I am blowing the BLANK file and then the nodemcu_512k.bin file just to be sure.
In each case after doing this.. If I send the file below to the unit.. it works... BUT the delay is too short to show the IP address.
When I say WORKS I mean one initial message and one run of the code.
There are TWO things wrong.
Firstly If I then RELOAD the file - subsequent powerup goes wrong - there is something wrong with your file.remove() command
Secondly if I try to change the time delay HERE...
file.writeline([[wifi.sta.config(ssid,pw)]])
file.writeline([[tmr.delay(500000)]])
from half a seconds to 2 seconds....
EITHER by making it longer OR using it 4 times..
i.e.
file.writeline([[tmr.delay(2000000)]])
or
Either way this FAILS and the unit ends up in a loop - Am I right in guessing this is some kind of WATCHDOG issue?
Is it possible to fix these two issues - we are SO CLOSE!!
file.remove("init.lua")
file.open("init.lua","w")
file.writeline([[print("Petes Tester 4")]])
file.writeline([[tmr.alarm(15000, 0, function() dofile("thelot.lua") end )]])
file.close()
file.remove("thelot.lua")
file.open("thelot.lua","w")
file.writeline([[print("Stopping timer")]])
file.writeline([[tmr.stop()]])
file.writeline([[print("creating function")]])
file.writeline([[connecttoap = function (ssid,pw)]])
file.writeline([[print(wifi.sta.getip())]])
file.writeline([[wifi.setmode(wifi.STATION)]])
file.writeline([[print("Connected to ",ssid," as ",wifi.sta.getip())]])
file.writeline([[end]])
file.writeline([[print("Running function")]])
file.writeline([[connecttoap("loft-east","1921681974")]])
file.writeline([[print("Done")]])
file.close()
I've made contact with the chip manufacturer Espressif.
the tmr.delay() issue is caused by watchdog, and so is the long time loop issue.
since Espressif doesn't offer function to init/disable/enable watchdog in SDK, there is little we can do.
they do give me a method to clear the watchdog count.
I have tested it by separate delay time into several 1-second, it worked.
when I delay more than 3 seconds(say 5s), no hardware reset caused,
but a "beacon timeout" occurred, the chip lose connection to AP, and will reconnect to AP, obtain a IP using DHCP, again.
if you have a tcp connection, it will disconnect.
and there is no function to deal with "beacon timer" neither.
Anyway, it's better than hardware reset.
I will release a update soon, fix tmr.delay(), and may add a tmr.wdclr() or something.
