scargill wrote:So I did some more tests this morning.
Examples from here: https://github.com/nodemcu/nodemcu-firmware
The TELNET example does not work and results in the module resetting every time..
The Web page example looks exciting at first.. but I noticed the browser returned the result "Hello NodeMCU but was constantly busy... and as browsers do, it retries the page.. and after 5 retries, the ESP-01 resets. Here's the output I monitored on the serial.
So here is the power up sequence and my init file getting an address from the router - all of that works..
Pete's LUA module 0.1
NodeMcu 0.9.2 build 20141120 powered by Lua 5.1.4
> c_GORSvfJSz.JSzfn
Loading functions
Connecting
Connected to.loft-east.IP:.192.168.0.22
OK
and then here is where I add in the web page example
> srv=net.createServer(net.TCP)
> srv:listen(80,function(conn)
>> conn:on("receive",function(conn,payload)
>> print(payload)
>> conn:send("<h1> Hello, NodeMcu.</h1>")
>> end)
>> end)
and then here is the result...
> GET / HTTP/1.1
Host: 192.168.0.22
Connection: keep-alive
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
User-Agent: Mozilla/5.0 (Linux; Android 5.0; Nexus 10 Build/LRX21P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.59 Safari/537.36
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-GB,en-US;q=0.8,en;q=0.6
but then wait... the browser of course gets the page again... and again. and....
GET / HTTP/1.1
Host: 192.168.0.22
Cache-Control: max-age=0
PANIC: unprotected error in call to Lua API (attempt to call a nil value)
c_GORSvf
SzfJSzfn
Loading functions
Connecting
OK
So a quick test suggests it works - but in fact after a few refreshes - the unprotected error occurs and the board resets.
I got the same error, after 10+ refreshes.
sorry, some examples need more tests, before it's writen in the doc.
the code below disconnect with client when payload is sent. may be it's better, still little tests made.
print(payload) print(node.heap())
end)
end)
