Yesterday I managed to get HTTP AUTH to work. Here is my code:
wifi.setmode(wifi.SOFTAP)
wifi.ap.config({ssid="TEST_AP",pwd="Test12345678"})
print(wifi.sta.getip())
led1 = 4
gpio.mode(led1, gpio.OUTPUT)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _, _, auth = string.find(request, "%cAuthorization: Basic ([%w=\+\/]+)");--Authorization:
if (auth == nil or auth ~= "dXNlcjoxMjM0")then --user:1234
client:send("HTTP/1.0 401 Authorization Required\r\nWWW-Authenticate: Basic realm=\"ESP8266 Web Server\"\r\n\r\n<h1>Unauthorized Access</h1>");
client:close();
return;
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
buf=buf.."<html><body>"
buf = buf.."<h1> Control Web Server</h1>";
buf=buf.."<p> Please Enter Your Password </p>"
buf=buf.."<form method='get' action='/'>"
buf=buf.."<p>Password: <input type=password name=pass </p> "
buf = buf.."<p><button type=submit>Submit</button></p>";
buf = buf.."</form></body></html>"
local _on,_off = "",""
if(_GET.pass == "test")then
gpio.write(led1, gpio.HIGH);
tmr.delay(2000);
gpio.write(led1, gpio.LOW);
client:send(buf);
client:close();
collectgarbage();
end)
end)
My code has 3 levels of authentication. These are the network itself, HTTP auth and a password sent through HTTP post. I am pretty happy with my code so far however there is one small problem. The password sent through HTTP Post is sent in plain text. Would it be possible to encrypt the password on the client side via html code and then decrypt it on the server side?
Could MD5 or SHA1 be used for this?
If so how could I implement this kind of encryption ?
How did encrypting user/pwassword ?
if (auth == nil or auth ~= "dXNlcjpwYXNz")then --user:pass dXNlcjpwYXNz
client:close();
return;
With the help of this page I could add a basic authentication to my ESP8266 web server. It works perfectly in every web browser. My only problem is once I am logged in through a browser it stays logged even after I reboot ESP8266 or I exit the browser. Is there any way to add a log out or a timer for automatic log out.
Thanks
