By Mikey
#34112
devsaurus wrote:Easiest way would be to flash a different (older, newer) version, do a file.format() there and re-flash your target firmware.
Thank you, that did a bit of the trick!!! :D :D :D
I spend some time on google to find an old version of NodeMCU, flashed it, restarted the ESP8266, and it is back working. But when I flash the newest version, it is stuck again.
UPDATE
I found a dev version of NodeMCU, flashed it, did the file.format() flashed current release again, and it is working! :D Hell yeah! This is valuable information for next time it goes wrong, because it most likely will again. ;)
