just want to say that I don't have a problem compiling dev branch using ubuntu.
I just did a
make clean; make
(forgot how long that takes ...) and then
make clean all
make flash
connect, reset, 20696 bytes heap.
Good luck,
Carsten
Explore... Chat... Share...
make clean; make
make clean all
cal wrote:just want to say that I don't have a problem compiling dev branch using ubuntu.
Markus Gritsch wrote:cal wrote:just want to say that I don't have a problem compiling dev branch using ubuntu.
Carsten, can you or someone else please attach the mapfile of your working build on Ubuntu? Here on Windows it is located at nodemcu-firmware\app\mapfile. Probably the same on Ubuntu.
Thanks,
Markus
