- Sat May 09, 2015 2:51 pm
#17024
I'm still at a total loss with this unit. I can flash the device without any errors being reported, If I flash the 512K blank image at 0x00000, when I boot, it doesn't hammer the Tx LED, just outputs:
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
ets_main.c
(this at 74880 baud)
I've tried different programming speeds, the same rig I'm using to program this chip has been used to successfully load NodeMCU to another device (so voltages, resistors, and FDTI are good).
It's as if the processor itself doesn't like the code.
Of the various images I have available, since none seem to work, but all seem to blow out with different exception addresses, I located one which has an object listing, figuring if I can locate the exception address in there when THAT load is running, I'll at least have a better idea of what might be going wrong (but bearing in mind that I've done absolutely NO coding on this processor complex and don't even have the cross compile toolchain installed). I loaded that imageset to the device and then booted it.
Here's the boot on a console:
Connected to COM11 at 74880 baud
load 0x40100000, len 612, room 16
tail 4
chksum 0x12
load 0x3ffe8000, len 788, room 4
tail 0
chksum 0x50
load 0x3ffe8314, len 264, room 8
tail 0
chksum 0x4a
csum 0x4a
2nd boot version : 1.1
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 32Mbit
jump to run user1
Fatal exception (0):
epc1=
0x40211558, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
(the exception just fires endlessly)
Would be nice to know what the "room" and "tail" are, and where the load address determination is coming from.
So, from at_v0.20_14_11_28\at_v0.20_on_SDKv0.9.3\bin\user1.S, we have the following context for that instruction pointer:
40211550:
2e28 l32i.n a2, a14, 8
40211552: ff .byte 0xff
40211553: 3f .byte 0x3f
40211554: fea750 excw
40211557: 3f .byte 0x3f
40211558: fffe61 l32r a6, 40211550 <wdt_init+0x2f0>4021155b: fffe41 l32r a4, 40211554 <wdt_init+0x2f4>
4021155e: 050c movi.n a5, 0
40211560: 07b467 bgeu a4, a6, 4021156b <wdt_init+0x30b>
40211563: 004452 s8i a5, a4, 0
40211566: 441b addi.n a4, a4, 1
all of this is in the wdt_init function. I have NO sources for this to know what the C code would have been.
I referred to the Xtensa architecture manual, and L32R is "Load literal at offset from PC" In reading up on that instruction, I note the following : Unless the Unaligned Exception option is enabled, the processor does not handle misaligned data or trap when a misaligned address is used;
Sadly, the architecture manual does not appear to identify specific values associated with the different type of exceptions, so I have no idea what an exception 0 even is on this device.
Elsewhere, I located an Extensa Instruction Set Architecture manual, and in there I found a list of exception values:
0 IllegalInstructionCause Illegal instruction [Exception Option]
The instruction in the listing seems to be AT the offset, implying it wasn't say vectored into part way through an operand I don't get it.
Exception 28 seems to be another exception that pops up in some threads I've read, though is not what I'm running into here:
28 LoadProhibitedCause A load referenced a page mapped with an attribute that does not permit loads [Region
Protection Option or MMU Option]
I'd like to get this device working - it seems so wonky that I can clearly re-flash, but there's something wrong in the initialization. I'm extremely leery of ordering more when #1 out the box is crap.
Refs:
http://ip.cadence.com/uploads/pdf/xtens ... ndbook.pdfhttp://0x04.net/~mwk/doc/xtensa.pdf
