By marcelstoer
#17141
A nice improvement would be to add an option to disable SSL (#define CLIENT_SSL_ENABLE in user_config.h)
Yes, indeed, wouldn't it. I'd really like to offer selecting options that go into user_config.h. However, there are current limitations on the GitHub API I don't know how to work around yet that prevent this.
By Vleis Walker
#17193
marcelstoer wrote:If you regularly want to build your custom NodeMCU firmware I suggest you give http://frightanic.com/nodemcu-custom-build/ a spin. You select the branch to build from, select the user modules to include (to reduce firmware size) and my service will build a firmware just for you.
THANK YOU!!! Looking GREAT! Works well!
However, Im a bit new to this....
I received 2 files... integer and float....
Which should be flashed where in ESPFlasher?
If this had been answered, please forgive and direct me.
Thanks for the great work!!
By cwilt
#17194
Choose one based on if you need floating point math or not and install as usual.
