ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 27528, room 16
tail 8
chksum 0x6d
load 0x3ffe8000, len 2184, room 0
tail 8
chksum 0xca
load 0x3ffe8888, len 8, room 0
tail 8
chksum 0x91
csum 0x91
don't use rtc mem data
;l???Just when i edit the baud rate from 115200 to 9600 in the user_config.h file in the app/include folder from the firmware
from this:
#define BIT_RATE_DEFAULT BIT_RATE_115200to this
#define BIT_RATE_DEFAULT BIT_RATE_9600the error message gone every restart
even flashing the esp_init_data_default.bin to the adress 0x7c000 or 0x3fc000 from the esp_iot_sdk_v1.4.0_15_09_18 SDK, and no error message when the module restart, all my lua scripts have a bad behaviour that ran perfect on the past 0.9.5. firmware.
I´m stuck at this point.
I really think that someone with the good knowledge must write a ultimate guide to sucessful flash of a new (master or dev) firmware into the esp (1, 2, 3.......12 or 12E) that way more people arround the globes can give something, even small, the the maker, hack and developer comunity.
Thanks in advance
