Not really sure what files and what addresses should i use when flashing newest version.
I am trying according this documentation, https://nodemcu.readthedocs.io/en/dev/e ... x-firmware
I have this downloaded esp_init_data_default.bin (file size: 128 bytes) and i used custom build nodemcu-master-7-modules-2016-07-08-17-18-11-integer.bin (file size: 380 928 bytes)
Should i leave first line flasher default? ( i am not really sure what is that)
What second and third line should be used?
So i use ESP-01 : it should be 512kb, 26Mhz, and i use 9600boundrate, QIO mode when flashing
but when i try to flash it shows 4Mb in first window at the right bottom corner.
I tried this configuration which did not worked(which gives Error:Write flash timeout. ):
