When I tried to attach a DHT11 sensor to the board, I got an error that the "dht" module was not available. After some research I found that the 0.95 build 20150318 version of the firmware does not include the "dht" module.
I went to http://nodemcu-build.com/ and built custom firmware that included the "dht" module. After flashing the ESP8266 I'm able to read temperature and humidity data from the DHT11 sensor, but the "wifi" module no longer lists the access points nor does it get an IP address.
Thinking that I might have done something fatal to the wifi circuitry, I re-flashed the 0.95 firmware and tested again. After re-flashing I was once again able to connect to my wifi access point and download a page from the Web.
Does anyone have any advice for how to get both the "wifi" module and the "dht" module to work at the same time? Or do you know where the appropriate forum for this question is?
Thanks,
Chuck
