iHaveESP wrote:I think those buying "Large-capacity flash-4M" modules are getting fooled, it's just 512Kb.
My modules have arrived and really have 4MByte flash (0xEF/0x4016 which translates to a Winbond W25Q32 flash chip).
Explore... Chat... Share...
picstart wrote:There is no mention of where 0xEF/0x4016 comes from unless it is lasered onto the chip itself. So maybe the responder is saying the tin can was popped off and the chip's lasered label read.
picstart wrote:The issue of the thread mostly seems to be what does lua report either by node.flashid() or the undocumented
node.flashsize.
picstart wrote:With a W25Q32 installed ( lasered on the chip) I'm getting an id 1458415 and a size of 512K.
picstart wrote:The suspicion is lau has things wrong and it always reports the 512 chip regardless of what actually is installed.
If lua was working there would be no need to look at the chip directly to get its capacity.
1458415 is 0x1640EF, EF is obviously the manufacturer code and if you swap the other 2 bytes, you get 4016.
