NodeMCU 0.9.5 build 20150213 powered by Lua 5.1.4
lua: cannot open init.lua
> m = mqtt.Client("ESP1", 120, "user", "password")
> m:connect("192.168.15.22", 1883, 0, function(conn) print("mqtt connected")
>> print(wifi.sta.status())
Using version 20150127 seems to have an MQTT issue also.
executing this line by line works:
print(wifi.sta.getip())
msg = "19.8"
m = mqtt.Client('test_sensor', 120)
m:connect("192.168.0.1", 1883, 0, function(conn) print("connected") end)
m:publish("sensors/test/temp",msg,0,0, function(conn) print("DATA sent!!") end)
m:close()
But saveing it to a script and call it via DoFile does not work. Can anyone confirm?
I reported the broken MQTT in https://github.com/nodemcu/nodemcu-firmware/issues/237
--MQTT.lua test code for NODEMCU 0.9.5 build 20150213
--LICENCE: http://opensource.org/licenses/MIT
--Over engineered by: MikeV for an ESP01 module
--External modules
t=require("DS18B20") --see http://tech.scargill.net/lua-and-the-ds18b20ds18b20p-temperature-sensor/
--Configuration parameters & initialise variables
broker = "192.168.1.108" -- IP or hostname of MQTT broker
mqttport = 1883 -- MQTT port (default 1883)
userID = "" -- username for authentication if required
userPWD = "" -- user password if needed for security
clientID = "ESP1" -- Device ID
GPIO0 = 3 -- IO Index of GPIO0 which is connected to a DS18B20
GPIO2 = 4 -- IO Index of GPIO2 which is connected to an LED
gpio.mode(GPIO2,gpio.OUTPUT) -- Make GPIO2 an output
count = 0 -- Test number of mqtt_do cycles
mqtt_state = 0 -- State control
function mqtt_do()
count = count + 1 -- For testing number of interations before failure
temp = t.readNumber(GPIO0) -- get reading from DS18B20
if mqtt_state < 5 then
mqtt_state = wifi.sta.status() --State: Waiting for wifi
elseif mqtt_state == 5 then
m = mqtt.Client(clientID, 120, userID, userPWD)
mqtt_state = 10 -- State: initialised but not connected
m:on("message",
function(conn, topic, data)
print(topic .. ":" ) --topic is not examined only printed for the purposes of this test
if data ~= nil then
print(data)
if data == "OFF" then -- Only "OFF" or "ON" is recognised to change GPIO2 state
gpio.write(GPIO2,gpio.LOW)
elseif data == "ON" then
gpio.write(GPIO2,gpio.HIGH)
end)
m:on("offline",
function(conn)
print("Offline!")
mqtt_state = 10 -- State: reset to initialised but not connected
end)
elseif mqtt_state == 10 then
m:connect( broker , mqttport, 0,
function(conn)
print("Connected to MQTT:" .. broker .. ":" .. mqttport .." as " .. clientID )
m:subscribe("sensor/"..clientID.."/action",0,
function(conn)
print("subscribed!")
mqtt_state = 20 -- Go to publish state
end)
end)
elseif mqtt_state == 20 then
mqtt_state = 25 -- Publishing...
if gpio.read(GPIO2) == 0 then -- Read the current state of GPIO2
io_status = "OFF"
io_status = "ON"
m:publish("sensor/"..clientID.."/temp", temp.."C GPIO:"..io_status.." #:"..count.." ", 0, 0,
function(conn)
-- Print confirmation of data published
print(temp.." degC GPIO:"..io_status.." #:"..count.." published!")
mqtt_state = 20 -- Finished publishing - go back to publish state.
end)
else print("Publishing..."..mqtt_state)
mqtt_state = mqtt_state - 1 -- takes us gradually back to publish state to retry
--Run it!
tmr.alarm(0, 1000, 1, function() mqtt_do() end)
Thanks do the guys at NodeMCU GitHub suport once again.
