So is there a simple wait, pause, delay that I can put in after the GPIO=high before I can set it to low again?
Explore... Chat... Share...
if(_GET.pin == "ON1")then
gpio.write(led1, gpio.HIGH);
ticker=millis();
repeat
print ("hello");
-- do nothing as it is a delay
until ( (millis() - ticker) > 2000 )
gpio.write(led1, gpio.LOW);
unsigned long ticker;
function turnOffLed()
-- you figure out this part
-- Turn on Led and then turn it off in 2 seconds
turnOnLed()
tmr.alarm( 0, 2000, 1, turnOffLed )
... execution continues with your other code immediatly
