By Falesh
#54761 First of all I am a linux newbie so I may well be doing something dumb. ;) This is what I did:
Code: Select allsudo apt-get install arduino
Opened a terminal at: /usr/share/arduino/hardware/
sudo mkdir esp8266com
cd esp8266com
sudo git clone https://github.com/esp8266/Arduino.git esp8266
cd esp8266/tools
sudo python get.py
After opening the Arduino IDE with a Doit NodeMcu Lua ESP8266 ESP-12E plugged in there are only options for the Arduino boards in tools>boards and nothing obvious in tools>programmer.
Any idea what I have done wrong?
By bbx10node
#54770 I suggest undoing what you have done so far.
Download IDE 1.6.11 for Linux ARM from arduino.cc. Get the Linux ARM (experimental version). This should work for raspi 3 as well but not for older Pi's. Also not for Pi Zero.
https://www.arduino.cc/en/Main/Software
Untar it on your home directory and run it.
Code: Select all$ cd
$ tar xf arduino-1.6.11-linuxarm.tar.gz
$ cd arduino-1.6.11
$ ./arduino
See the following to install the ESP8266 support package.
https://github.com/esp8266/arduino#inst ... ds-manager
