By sej7278
#14762 just tried https://github.com/sandeepmistry/esp8266-Arduino with 1.6.1 and 1.6.3 on linux (default arduino distribution, not esp8266 fork) and i can compile just fine but can't see esptool in the programmer list.
why are we using esptool anyway, i thought that was deprecated in favour of esptool.py ?
my directory structure is:
Code: Select all~/arduino16/hardware/esp8266com
└── esp8266
    ├── boards.txt
    ├── cores
    ├── libraries
    ├── platform.txt
    ├── programmers.txt
    ├── sdk
    ├── tools
    └── variants
that's inside my "sketchbook" directory, not inside the arduino ide itself, although i've tried that also.
1.6.4 nightly is completely screwed up:
By gambituk
#14903 You don't need to have it listed as programmer, just follow the install instructions and test, if you can see the board and ports, then that's all you need with 1.6.3. If you are having other issues it is some other cause, for example, when i installed it wouldn't compile for me and i got misled down this rabbit hole, but in fact it is not the problem, i was getting compiler error but after downloading a missing dll it is now resolved for me.
Hope this helps.
