adlmail wrote:I have the exact same problem as Kooth. Boards manager (in 1.6.5) hangs up saying "Downloading platforms index...Downloaded 22kb of 44kb" I tried your suggestion of using "staging" version-same result and hang. I have reloaded 1.6.5. I have tried the .git download procedure outlined but my DOS does not have a git command. I am running on Windows XP. Trying to get a Sparkfun ESP8266 shield going.
thanks.
I had a similar sounding problem using XP and was able to solve it by determining the file that it could not load and then manually loading that file and any others past that point into the directory for the install. Then board manager worked and and it has worked well subsequently and including updating to several new stable and staging versions.
I wrote about it here: viewtopic.php?f=26&t=4464
I ended up having to use a Win 7 to upload the "stuck" file. Your problem may be completely different but I thought that there are enough symptom similarities to warrant mention.
