By Dave Wilson
#31098 I have the same problem. I upgraded to El Capitan yesterday and now I can't flash my ESP-1. It does recognize the serial port because I can get debut output. I've tried a couple of different ESP-1 devices. No luck. I've seen references to device signing issues.
Error messages
Sketch uses 257,344 bytes (49%) of program storage space. Maximum is 524,288 bytes.
/Users/davidwilson/Library/Arduino15/packages/esp8266/tools/esptool/0.4.4/esptool -vv -cd ck -cb 115200 -cp /dev/cu.usbmodem14211 -ca 0x00000 -cf /var/folders/mz/d9j7rvpx33jfdx38m1gtpzc80000gn/T/build4218092617509108676.tmp/ESPNightwatch.cpp_00000.bin -ca 0x10000 -cf /var/folders/mz/d9j7rvpx33jfdx38m1gtpzc80000gn/T/build4218092617509108676.tmp/ESPNightwatch.cpp_10000.bin
esptool v0.4.4-5-g744c44d - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.usbmodem14211
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
stat /var/folders/mz/d9j7rvpx33jfdx38m1gtpzc80000gn/T/build4218092617509108676.tmp/ESPNightwatch.cpp_00000.bin success
opening port /dev/cu.usbmodem14211 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
setting character timeout 0
done
setting character timeout 1
done
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
resetting board
trying to connect
done
done
trying to connect
done
done
trying to connect
done
done
warning: espcomm_sync failed
error: espcomm_open failed
