This seems to be working well! I've got the blink sketch up and running too!
Next stop .. build a webserver!!!
Cheers legends!
Explore... Chat... Share...
Ayden wrote:Hello,
I have tried the methods mention and able to flash successfully to the ESP8266. But after I reduce the wire and connect it to the led from this website http://www.arduinesp.com/blink. The led doesn't blink. Can I check if I have done anything wrong?
Thanks
