tytower wrote:When you play with these things its expected that you will do the research yourself not keep asking others to do it for you . That's the fun , research it , think it through a,build it and then you get the satisfaction of doing it yourself when it works.
The reference you put up says
DC Current per I/O Pin 40 mA
DC Current for 3.3V Pin 50 mA
The 5 V will only get what the computer puts out for that particular board . Probably 250 to 500 mA , I don't remember. So you can try it and see but if its erratic suspect the power supply first
Yu need to research the RX/TX lines .. I thought I saw they were not crossed but that was for programming another arduino chip. You might have to cross them for what you want.
Thanks - I'm not too concerned about the Rx/Tx as I can, as you said, play around with it. The thing I'm trying to avoid is releasing the magic smoke The majority of the parts for my project (Including the ESP8266) come in on Monday, so I'm just doing pre-planning, which is why I'm probably way overthinking it
As for the 5v - I'm not so much concerned with its short term power availability when hooked to the computer, but the overall project is going to be standalone, and while the Arduino does have the AC plug point, the USB based power solutions tend to be more compact, which works best for my purposes. I can reliably send 1A through the 5v via that method which means that power shouldn't be an issue.
Thanks again for your help!
